oil leak
  • cochran
    • Sep 2005
    • 78
    oil leak
    I had a minor oil leak (annoyance level) that suddenly got worse on Friday. Tracked it down today to loose connections for the oil cooler. Anybody else seen this? The one closer to the radiator was the leak, and was finger-loose. Both connections were actually loose. Fixed now, and engine freshly degreased after all the blown oil, but I didn't expect this to be a problem area. Glad it was such an easy fix, and I guess any connection is liable to loosen after this many miles.
    Cochran
    '88 325iC - daily driver, work in progress
    That's not an uncommon problem. Those hoses are o-ring sealed and there's a good chance that new o-rings are indicated. They are pretty cheap...
    • NomadE30
      • Mar 2007
      • 236
      yep had to replace mine, only cost me 3 dollars for 8 of them at checker.
