could someone with some experience on the subject lend some advice ?
ive got idle issues namely my idle wants to hunt between 500 and like 1200 rpm.
my car is an 84 325e.
ive sprayed every connection and possible opening with carb cleaner with no results. ive cleaned and tested my icv... several times. nothin.
its kind of an intermittant problem too it seems to get worse when the cars warm
removing the oil filler cap and or dipstick doesnt change the idle at all and disconnecting vacuum hoses doesnt do much either like for instance if i disconnect the brake booster line it runs almost the same
if i disconnect the icv electrical connector it goes to the failure mode where it revs up cuts fuel revs up etc
so is this a huge vacuum leak or what?
ive never compression checked the engine but it does use some oil on the highway. could excessive blow by into the pcv system cause these symptoms? there is quite a bit of oil in the throttle body
my intake boot fits a little bit loose on the maf end but once its clamped up i can spray the shit out of it with carb cleaner with no change to the idle, injector o-rings, and all hoes onto the intake boot give me nothin when i spray the connection ends
where else can i look?
