Just finished replacing the timing belt, and everything is fine, except the carr is running really hot. The temp. gauge gets to 3/4 on the red side just sitting at iddle, which it didn't before. I just replaced the thermostat, and had the crank and intermediate shaft seal cover off, so most of the coolant came out of the block.
How do you guys bleed the cooling system on a 6 cyl. between the overflow resevoir and the bleeding screw on the thermostat housing? So I need to open the coolant drain plug on the block??
Here another idea of mine:
During the timing belt swap, I also replaced the thermostat. The thermostat had an 87 stamped on it, which I think may be the temperature at which it opens. What temperature thermostat do the 6 cyl's call for?
thanks.
R
thanks.
R
