ICV for ITB's...
    ICV for ITB's...
    What are you guys using? Anything? I'm thinking about running a stock ICV (maybe the two pin one) and mounting it remotely and piping it in to the manifold TB's individually - OR is there a way where I can get around this say with a different A/F mixture, etc.?Going to be running a full EFI ITB setup on an m20.Thanks
    Are you running a stock motronic?
    If not. You can just use a idle air bleed valve. (custom)
