eta with i TB and IM.What happened?
  • TopOfTheLine89
    • Jun 2007
    • 919
    Well i switched from eta intake mani and TB to "i" intake mani and TB. car was idling alright but had no throttle responce, would dies if i stomped the pedal like it may have had a vac leak at the itake mani or fuel injectors? So i pulled the intake manifold and replaced the O rings on all of the injectors and the manifold gaskets. put it back on.
    Now the car is running on one cylinder. it barely idled as i pulled off plug wires to see that only one cylinder was doing anything. I tested the plugs they are all doing there job so somehow only one of my injecors is working. How hard is it to break and injector? I did a few tests omh's seems low on most of the injectors read 1 instead of 2-3 like its supposed to. What damage could have been done pulling the intake manifold and removong the injectors a few times? Any help or suggestions would be much appreciated.
    97 tacoma 5 spd 4 cylinder
    2001 330ci 5 speed
    83 733i 5 speed, (FS)
  • TopOfTheLine89
    • Jun 2007
    • 919
    Any ideas from anyone on what may cause injector failure?
    2001 330ci 5 speed
    • TopOfTheLine89
      • Jun 2007
      • 919
      "well young ethusiast try firing the injectors out of the car to see if they are working"
      2001 330ci 5 speed
      • TopOfTheLine89
        • Jun 2007
        • 919
        gee, thanks Mr.
        2001 330ci 5 speed
        • TopOfTheLine89
          • Jun 2007
          • 919
          "No problem sunny boy"
          End thread/
          2001 330ci 5 speed
            • 37832
            Did you use the e injectors?
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • TopOfTheLine89
              • Jun 2007
              • 919
              Yeah, i used the e injectors but i guess they are bad, so i put in the i injectors(yeah i know your not supposed to) for now and its firing on all cylinders again, hopefully gonna megasquirt soon. Its running really rich and i think its due to my coolant temp sensor cause my gauge isn't reading any.
              2001 330ci 5 speed
