Basically, what happens is, I can drive on the side streets without issue.
but after about 10 minutes on the freeway at 65 mph (4th or 5th, usually kick into 5th around here) the car starts dogging like it's out of gas
much of this started after I got a new catalytic converter like the first freeway drive afterwards (the old one was hollowed out with a hole in the side)
I've replaced the fuel pumps which were bad because there was a lean-ness issue that was killing the catalytic converter
though, much of this started after I got a new catalytic converter like the first freeway drive afterwards (the old one was hollowed out with a hole in the side)
I know my water pump has a very slow leak in it because I see wetness around it and air in the cooling system after about 90 miles or so.
no froth, no oil in the coolant, no coolant in the oil, no smoke or steam from the exhaust, so I dont think it's a head gasket issue.
Someone suggested it may be the ecu or the AFM
I think it may be the catalytic converter as all this started right after I got it, if not that, the ignition coil, but as I'm not a master mechanic (I fix computers, not cars as a career) I want to know if anyone here knows what it could be?
I'm absolutely stumped.
