M20 engine weight...plus pic
  • Drew325is
    • Oct 2004
    • 520
    So I actually weighed my M20, pretty much as it's found in the engine bay. Weight is in kilograms:
    The flywheel was removed...all the ancillaries still attached...even has oil in it. I am not sure anyone has actually weighed a fully dressed M20 before (couldn't find it in a search anyway), but I've always wondered if the typically quoted figure of 117kg was a bare M20 or not...I'm confident to say 117kg is a bare weight. I plan on weighing the M52 before it goes into the engine bay for comparison.
  • Baxter
    • Apr 2007
    • 40
    roughly 400 lbs......cast iron ftmfl
    • FredK
      • 14761
      Great work, Drew! I don't think I've seen a fully dressed weight of an M20 either.
      I did see a weight for a fully dressed M42 with transmission, though. It was 427 lbs with intake and transmission, and since the transmission weighed 68 lbs, the engine itself was around 359 lb (163 kg). This information was reported by Vorshlag Motorsport.
      • Madhatter
        • Oct 2004
        • 966
        117 is a long motor with no fluids.
        from the list
        Engine weights are for a dry engine with no manifolds, starter motor, alternator, etc.
        Just a little project im working on
        - http://www.lse30.com -
        • Drew325is
          • Oct 2004
          • 520
          And just cus I have the pic handy...Getrag 260+fluid
          • Boomerang
            • Feb 2007
            • 224
            a super eta block with rods, pistons, oil pan, was 197 pounds
            • Drew325is
              • Oct 2004
              • 520
              I weighed the M52B28 today...did my best to do everything the same as when I weighed the M20...the only difference is that the M52 has no oil, no wiring harness, and no throttle body (the alternator is there, but buried under the M50 manifold in the pic)...can't really think of anything else significantly different between the two engines that'd mess with the weight result:
              I was honestly quite surprised by the result...I didn't think there'd be much difference but, 30kg is a fair bit. Maybe 20kg with the M52 in a running state.
              Oh...and I have the VAC motorsport billet oil filter housing on the M52, instead of the OEM one...so that'd be a bit lighter than an OEM M52.
              • Jean
                • 18228
                Nice! m52 aluminum block ftw :D
                • 328ijunkie
                  • May 2007
                  • 3961
                  Wait you have the Alum M52 outta the Z3?
                  Check Us out on Facebook
                  Full Product Line Tuning
                  • Drew325is
                    • Oct 2004
                    • 520
                    Yeah it's Z3 or 528i...not 100% sure...either way, definitely alloy block.
                    • 328ijunkie
                      • May 2007
                      • 3961
                      Noice
                      • madjurgen
                        • May 2005
                        • 1203
                        Wow, internet hearsay always led me to believe that the m20 and alum m52 weighed the same. 55lbs is a pretty huge difference.
                        As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
                        You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
                        • z31maniac
                          • 17566
                          What about the weight of an S50 or 52? Are they the same alloy block? So they would have a similiar weight?
                          www.gutenparts.com
                          • ApexGoblin
                            • Jun 2011
                            • 888
                            does anyone have the actual photo of this saved? gotta love photobucket un hosting shit lately
                            apexgoblin - versteht nicht jeder. Ist auch besser so!
                            • dvallis
                              • Oct 2015
                              • 1472
                              I think Digger has a picture of an M20 on a scale.
                              "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
                              1987 E30 3L Turbo Stroker Das Beast
                              2002 E39 M5
