My e30 Keeps BUCKING! PLEASE HELP!
  • scm320
    • Aug 2007
    • 57
    Okay so heres the deal. Ive had this problem for about two to three months. When im driving it runs fine and then out of no where it will buck, a loss of power or something. its as if a spark plug is shot or something. Ive change the spark plugs twice. i changed the wires. I cleaned my throttle body checked for vaccuum leaks, bought a new battery a new alternator and i still dont know whats wrong with it. PLEASE ANYONE!! can you help me!! ive tried and asked everyone and know one knows. i was told it MIGHT be the ignition coil but i rather be sure than spend more money on something that wont even fix it. I cant afford it. PLEASE HELP!!!!
    Having a fast honda is like coming out of the closet.....you suprise everyone at first, but in the end you're still gay
  • kamotors
    • Nov 2007
    • 7102
    leaky fuel injectors? that was my problem, but my car only bucks at low speeds
    7speedshop.com
    • e30frosh
      • Dec 2004
      • 2170
      TPS going haywire? Maybe recalibrate the AFM? Might even be the crank reference sensor...all just speculation of course.
      Every day I wake up we drink a lot of coffee and watch the CNN
      Every day I wake up to a bowl of clover honey and let the locusts fly in.
      Lobsterbacks attack the town again
      Wrap all my things in aluminum
      Beams of darkness streak across the sky
      Pink rays from the ancient satellite
      Every time I look out my window same three dogs looking back at me.
      Every time I open my windows cranes fly in to terrorize me.
        There's a number of possible causes of that, including:
        1) A flaky crank position sensor
        2) A bad connection at the C191 connector (feedss the fuel injectors)
        3) A bad FPR or failing fuel pump
        4) Flaky main or fuel pump relay
        5) Bad ground or power connections
        Since it is an intermittent problem, figuring out which is a matter of eliminating possibilities.
        • TopOfTheLine89
          • Jun 2007
          • 919
          while were on the topic, my car bucks at around 1300-1600 rpm if i let off the throttle. it wouldn't let me just hold 1400 rpm or it will buck. i have to be decelerating or accelerating for it to be smooth.
          97 tacoma 5 spd 4 cylinder
          2001 330ci 5 speed
          83 733i 5 speed, (FS)
          • scm320
            • Aug 2007
            • 57
            J levie how do i go about fixing these problems or test them at least. im running low on cash so testing and checking would be a lot better than getting new everything
            • hendrixvodu
              • Jan 2007
              • 2514
              ok....i had the same problem....so this is what it did....bucked constantly changes TPS.... ect ect....so i one day decided to change my o2 sensor i unplug it...but left it off....and it completely stopped....i put a new one on and it still does it....idk why but having it off fixed the prob....i just dont have an o2 now...weird?
              -His-
              87 e30 325i
              87 e24 m6
              05 e83 x3
              94 e32 740i 5spd
              -Hers-
              89 e30 325i
              18 f48 x1
              • hendrixvodu
                • Jan 2007
                • 2514
                oh and if that doesnt work try a new coil pack
                -His-
                87 e30 325i
                87 e24 m6
                05 e83 x3
                94 e32 740i 5spd
                -Hers-
                89 e30 325i
                18 f48 x1
                • scm320
                  • Aug 2007
                  • 57
                  thanks i will try disconecting it. because i put a new one on because it wouldnt pass emissions and it was fine but now for the past months its been weird but i wil try it and the coil pack
                  • scm320
                    • Aug 2007
                    • 57
                    OKay so heres the update! I changed my coil pack and it was doing well the first day and the second day it did it once but today it went buck wild. its as if i fix it then it comes back. and the o2 sensor all it did was make my check engine light come on. man this is hurting my pockets
                    • gmiller5m
                      • Jan 2008
                      • 22
                      I had a simular symptom but on a ODBII car. After changing coil packs, wires, and dealer changed the plugs. It ended up being a single bad plug even though it was brand new. Luckly the ODB showed which cylinder was misfiring and the misfire followed the plug when i moved them around. my gut said to check the plugs but I reassured myself that they must be ok. They weren't. Run a spark test on your plugs and see if any might have a weak spark.
                      • hendrixvodu
                        • Jan 2007
                        • 2514
                        x2 on this .....it has to be spark related
                        -His-
                        87 e30 325i
                        87 e24 m6
                        05 e83 x3
                        94 e32 740i 5spd
                        -Hers-
                        89 e30 325i
                        18 f48 x1
                        • scm320
                          • Aug 2007
                          • 57
                          Yeah i dont know what else. And its weird some days it wont do it at all! It always does it when its cold and only been warm for like 20 minutes but then after that it usually stops. ITS PISSING ME OFF!!! i will check that out though because buying to crap is killing me! thanks!
                            Unfortunately, since the youngest E30 is 17 years old, and since a problem like this may be the result of a number of contributing factors, you may wind up replacing quite a bit of stuff before getting to the point of actually being able to solve the problem. Age does take its toll and a general refresh of things related to the intake, fuel, and engine management system may be required.
                            Most things can be tested, but with an intermittent problem the test will be meaningless if the fault isn't present when the test is run.
                            • gedupsound
                              • Oct 2007
                              • 25
                              my car would do similar things, would star bucking like it was running out gas, and then fire up, the engine light would come on, etc etc. turned out it was a bad ecu, and the car was basically running lean and shutting down. replacement ecu solved the issue straight out. might not be the same issue. definitely worth a try. And if its not the ecu, dont worry, at some point it will go bad :)
                              95 Integra GS-R 4dr
                              89 325is coupe, baseline dynojet pull: 148hp, 150tq
                              AE86 Zenki Liftback, Miata Supercharged, others...
