Hi all, my 89 325i just decided to strand me, not 30 minutes after I had just driven it. I drove it from work back to school to work on the SAE car(5 min drive), then went back out about 30 min later and the car won't start. It has plenty of power, is cranking over just fine, has oil, has spark, but still won't start. It has 3/4 full tank of gas.
When I started the motor it ran fine for a couple seconds, then the rpm dropped down to 500, and no matter how much gas I gave it it stayed at or below 500 until it quit. This took about 10 seconds at best. I've been trying to crank it but still no luck; I've waited for a few minutes in between in case I flooded it but still nothing. Occasionally it will try to start(sounds like it's burning vapors) but then keep cranking without turning over.
So: what do you guys think the problem is? Fuel filter or fuel pump? How easy/expensive is it to replace either, and where can I find either component. I've had the car for a month and have done nothing to it except a couple tanks of good premium(91) gas.
This all has happened in the last hour and a half. I've called AAA and they're on their way with a flatbed to take me & Katja(car) home. :curse::sad:
Thanks in advance!
Thanks in advance!
