I have an 89 325i and recently my timing belt broke while driving. From the research I have done, it seems very common that this would cause damage to the cylinder heads. Any advice?
If I fix the timing belt and remove the head and get it repaired, do you think that would fix it? Do I need to be concerned about any other damage caused by the broke timing belt?
Any advice is greatly appreciated.
Thanks
Thanks
