engine oil check?? and now oil pressure check/
  • bimmer_E30
    • 5001
    ok so yeterday i was driving my car and the engine light check comes on , whene i went back home i changed the oil and now the check engine oil is off, after i changed the oil my pressure light come on, the one in the dashboard, so what should i do?? maybe i put more oil than the requierd.
    Originally posted by e30e
  • bimmer_E30
    • 5001
    bump.
    • bimmer_E30
      • 5001
      hello!!!!
        On the assumption that a dipstick check shows normal oil level and you used the correct weight oil, the first thing I'd try would be an OE filter if you used a generic. If that doesn't turn off the oil pressure light the next thing to do is to temporarily replace the oil pressure switch with a gauge and see what the idle oil pressure is. The OE switch trips at 5-7psi and at idle on a cold engine you should have way more pressure than that, say 30psi or more. On a hot engine in decent condition 15psi or more would be normal. If pressures are normal the switch is bad. But if you ran the car for any length of time low on oil the bottom end bearings could be damaged and there may not be normal oil pressure.
        • NC325iC
          • Mar 2004
          • 6565
          the dash light does not have shit to do with oil level that is an oil pressure light, it could be the switch is bad or you could have a bad oil pump, clogged lines, clogged filter, clogged pump
          • DaveSmed
            • Apr 2007
            • 1407
            Don't ignore it or drive the car with it on though until you know whats up with it. You very well could trash your engine by doing so.
            -Dave
            2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
            Need some help figuring out the ETM?
            • bimmer_E30
              • 5001
              allright iam goona change the filter aslo do i have to put a new oil too?? cause i just put synthetic yesterday 5W30. so first i will check the switch( where is it located at) .
                • 37834
                You can change just the filter, that's fine. The oil pressure switch is located on the bottom side of the block below the oil filter.
                Grover Beach, California
                BimmerHeads.com
                • ADEN
                  • 620
                  this happened to me last week while driving on the highway at night the oil light went on i check the oil it was good and full sound of the engine was normal too it the at the end i shaked the sensor wire the light went off i go on with driving after i was so scared of the oil light going on.try to do as i did the problem is from the sensor wire.if the pump you hear a strange sounds from the engine.
                  • bimmer_E30
                    • 5001
                    how does the enigine will sound like i will make a video tommorw of the engine sound.
                    • bimmer_E30
                      • 5001
                      hehehehe yah man it was that little fucking wire. my car is good again.
