OKay so i looked up what code 1261 means and this is what came up:
1261 - Fuel Pump Relay Control code indicates break or short circuit associated with fuel pump relay. Test for proper signal on number 3 pin on DME. It can also mean that output stage of DME is faulty (Motronic version 1.3 only)
So does this mean i need a new fuel pump relay? or a new DME? Is there a way to test these things first or something because i have no clue and i spent madd money already trying to make this thigns work right when i should have checked the code a long time ago.
thanks i appreciate it
