brake fluid
  • Chemicalbro13
    • Mar 2008
    • 35
    brake fluid
    is there any special brake fluid for my 325e?, I looked in the bentley and all it said was that it should be BMW aproved...so if there is a kind that is better then others that i should use then please tell me thanks!
  • FredK
    • 14761
    Not really. DOT 3 or 4 will work fine.
    Just pop on over to Auto Zone and get a 32 oz can of Valvoline Syn Power. Or, Supertech DOT 3 brake fluid at Walmart if you're on a budget.
    • Chemicalbro13
      • Mar 2008
      • 35
      thanks alot!
      • Chemicalbro13
        • Mar 2008
        • 35
        so i needed brake fluid because i thought this might be the culprit as to why my clutch pedal wont push in or com out much at all...and as i found out this wasnt the case. So i jacked the car up and removed the slave cylinder, the rubber gromet and the metal cup washer were all bent and shredded so i think there is a leak there...also the rod had a huge gash in it(I can put pics on if necessary)....so now i am ordering a new one but is this going to fix it?, basically i can put the car in 1st or any gear but i cant shift out of it or change gears!
