Help to much gas!!
  • charlieboypr
    • Mar 2008
    • 18
    Help to much gas!!
    my 87 325e was having some problems it has to much gas here in the forum i found out that the problem could be the o2 sensor i change it and the car improved a little but still has the problem what could it be? the fuel regulator pressure is ok and the coolant sensor too but i notice that the idle control valve and the cold injector are not connected help guys!!!!!
  • charlieboypr
    • Mar 2008
    • 18
    bump!
    • eugeman
      • Sep 2007
      • 306
      You need to correct the last 2 problems to get your engine where it should be. See how it improves and update your situation if necessary.
      • charlieboypr
        • Mar 2008
        • 18
        does two things can be the problem?
        • charlieboypr
          • Mar 2008
          • 18
          bump!
