so my car has always had a leak here but it has slowly gotten worse. not bad enough to need to add oil between oil changes. the oil level on the dipstick actually doesn't even change very much. i was just wondering what its leaking from. i wiped it down and it doesn't seen to be coming from above.it's engine oil not transmission oil. in the pic thats the front sway bar off to the bottom left. whats that little plastic square thingy behind the leak called?
