As soon as I bought my first E30 with 63K miles on it, I read all the "what motor oil to use" threads here and elsewhere & decided that it was OK to use synthetic oil, as long as it had 1200+ppm of ZDDP (zinc) to keep the M20 flat tappet cam happy. I conveniently dismissed the R3V advice that synthetic would make the M20 leak oil as the prissy fear-mongering of superstitious old ladies.
A month later and 800 miles after a dose of Mobil1 15W/50W specially formulated for old flat tappet cams, the M20 starts bleeding like a stuck pig. I get a nagging feeling that I should have listened (again).
Here's what I found - A steady drip from the oil filter housing at the spot indicated by the arrow:
So, 3 questions:
Q: Why don't I listen to people smarter than me?
Q: Does this drip location indicate a common M20 leak spot?
Q: If so, how do I fix it, and what parts do I need to order?
Thanks to all, and I'll gladly put up with verbal abuse if the right answer comes with it :)
So, 3 questions:
cing.com
