So, I made a slight miscalculation when removing my motor a few days ago, and it kind of hit the ground hard - it fell fairly quickly and landed smack dab on the oil drain bolt. I don't see any cracks at all, and the pan looks fine.
HOWEVER, now the oil drain bolt is pretty hard to remove and even after I tighten it really tightly, it still leaks, about a drip every minute or so.
Can I helicoil the drain hole or something, I'm guessing the treads may be damaged? Some ideas would be nice, cause when I get my motor back in, at this rate I'll lose almost a quart a day!
