The little plug next to the oil filter.....what's it called & how do I change it?
  • SoCal Life
    • Jun 2006
    • 323
    Yeah, what the title says?
    Mine is driping so I need to change it. I'm sure if someone just tells me what it's called I can search for a write up on it and do it.
    Any help.......???
    e30 325is - e30 M3 [FOR SALE] - Audi S4 - '78 F-250 .....clicky clicky
    The only plug near the oil filter that I remember on an M20B25 would be the coolant block drain plug. It is sealed via a crush washer. Replacing the washer, or the plug, is simple and obvious.
    But you might be referring to the oil pressure switch that is also near the oil filter.
    • StereoInstaller1
      GAS
      • 22679
      I was thinking the same thing.
      Closing SOON!
      Thanks for 10 years of fun!
      • DCColegrove
        • 2748
        Oil thermostat plug? Held in with a cir-clip?
        You get the kit from BMW (o-ring, clip and plate) remove the old one and replace it all.
        It is spring loaded in there so it takes 2 1/2 hands to put it in and snap the new clip.
        • sticksdaman
          • Apr 2005
          • 2987
          http://www.realoem.com/bmw/showparts...59&hg=11&fg=30
          i believe its number 7 youre looking for.... gunna need a needlenose pliers to pinch the two ends of the circlip togeter to remove it
          Originally posted by ebelements
          Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
          • SoCal Life
            • Jun 2006
            • 323
            Yeah, that's the one. I have cir-clip pliers so it should be a snap. Thanks guys!
