I know this topic has been covered a multitude of times but i am still having problems with overheating. Here is a list of parts i replaced.
New timing belt
New water pump
New v-belts
New fan clutch
I am currently not running a thermostat bc when i do the car overheats. When i am driving on the highway the temp. needle will be at about 1/4. It is only when i am in stop and go traffic that the temp. need will reach 1/2 and a little above. It should not be running at the 1/2 mark without a thermostat.
I have had the car on ramps and have bled the system. From listening to the car idling when its hot, it sounds like the fan just isn't spinning fast enough. Is there a sensor that may be bad? Any help is appreciated. thanks
New timing belt
New water pump
New v-belts
New fan clutch
