M20 motor mount removal?
  • buzdof
    • Jan 2008
    • 125
    Car: '85 325e
    Problem: Trying to replace the motor mounts but I just can't get to the top bolts.
    Here's what I'm doing and please tell me if there is an easier way: I loosen the lower mount nuts then get out from underneath the car and try to get the top nuts from above but I'm struggling to fit a wrench in there and get the leverage to loosen them. Any ideas?
    Thanks!
  • Sean
    • 5793
    Use a ratchet. If you use a 17mm socket on a ratchet, they should be very easy to get to from below and possible to get to from above. You won't get a wrench in there.
    - Sean Hayes
    • mattdk318i
      • Jun 2006
      • 3953
      long ass extension with universal from the top(on drivers side) And just a ratchet and socket for the pass side.
