Power loss until 4k rpm
  • mikeseta
    • 1
    So I've got a 1987 325 (eta motor). Recent build on the motor, mainly stock, but balanced bottom end and a mild port/polish on the head (just a polish, really). Headers and 2.5" exhaust, Jim Conforti chip, but everything else is bone stock right now; just nice and fresh.
    Suddenly I've got this driveability problem. Until about 4k, the motor revs very sluggishly and bogs a lot. As soon as you hit about 3-4k, the engine revs smoothly and powerfully right to redline.
    The problem is not coincidental with the recent work; it started a while after all of the goodies.
    AFM tests out fine, as do resistance checks of the crank engine speed sensor, the ignition components (all of which are new anyway), the air temp sensor, etc.
    It doesn't appear to be a fuel issue, since the pressure regulator and all of the injectors (including cold start) test out fine. Also, the plugs are a beautiful chocolate brown, so no rich or lean indication there. No rich exhaust smoke or anything of that nature.
    I'm thinking that something must be f'ed up with the ignition timing somehow... Any ideas? Anybody had a similar problem?
    Thanks a million.
  • E30_fiend
    • Apr 2006
    • 7348
    check out your TPS. Make sure it clicks when you turn the ignition on. If the AFM checks out then thats the only other thingI could think of. When my AFM was going bad it was doing the same thing as you described.
    Taylor
    • devonjordan
      • Jul 2006
      • 2386
      Thats just v-tech kicking in. V-TECH YO!
      Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
      Help a brother out, buy your detailing products here...
        I think my first suspicion would be an intake leak or bad AFM. I rather doubt that it is fuel, as a delivery/pressure problem should be worse as rpm increases.
