I swapped in m20b25 out of a 325is into a 88 325is.
The car will crank but not start.
I know the fuel pump is not turning on but it will if I jumper it.
Also the windows will not go up or down so I assume that the main relay is not turning on.
I looked at this thread:
It shows this wire as the problem.
But. What about the unloader relay. I think its pin 15. I have that on the chassis side but not the harness side.
What does that do?
Also what are the other 1 pin wires hanging off the ecu.
I also saw something about the OBC needing a code after a swap.
The other option is to take the engine harness off of the other motor and put it on the new motor. That looks like a PITA.
Need help to get this thing done.
What does that do?
