My guess would be yes it would need the ecu and harness since the seta head is pretty much the same as the is. Or at least thats what I have been told.
it would depend on what exactly you would be swaping over. if it was just the head then you wouldnt need the electronics. if it were the head intake manifold exhaust manifold you wouldnt need the electronics, but i think the throttle body and afm from the seta needs the seta electronics. and this is pure speculation but i would think with a seta head and eta block your power would be decreased due to lower c/r. but look around at some old threads youll find there are some ways of making power with the eta, you just gotta do some research.
Originally posted by Ferdinand
I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
the head is the same as the i, the cam is NOT. when you swap the b25 head to the b27 block, you get a lower compression ratio but maybe some power because of the better head flow and more aggressive cam. the super eta head is the same, but since the cam is still eta style it is just going to give you lower compression and flow increase but it wont matter with the weak cam, youll lose power.
oh i didnt see the bottom of his post ^ haha. the seta also does not have oil holes drilled for the extra journals the i cam uses, if i remember right.
