M50 17lb injectors
    M50 17lb injectors
    What would be the advantages or disadvantages of putting 17lb M50 injectors in a stock 325e? Would it be worth it or should I just clean the stock injectors?
    It wont work. The M50 injectors are high impedance injectors while your ETA's injectors are low impedance. the upgrade just simply wont work
      how about the mustang injectors?
        K thanks. Can anyone tell me the flow rate of my stock injectors?
          My memory sucks but I think eta's have 17.5
          "Life is hard...it's a lot harder if you're stupid."
          Tom
          72 2002
          87 327i
          88 525i
          88 535i
          03 530i
            The mustang injectors are still high impedance.
            The stock ETA has 18.5lb low impedance injectors. If you want to upgrade the fuel injection, upgrade to motronic 1.3. Either that or do the i head swap with manifold and injectors.
            Taylor
              yeah this topic has been touched upon a few times, and i know e30_fiend has answered this exact question before. its not really that hard to search. like i know it takes a little more effort to search, but it requires a lot less effort than somethings. things like walking to the store naked.
              Originally posted by Ferdinand
              I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
              DIVING BOARD DIVISION DIVISION IDIOT
