e to i motronic swap need help.
  • TopOfTheLine89
    • Jun 2007
    • 919
    Finally got around to swapping the i ecu. harness and sensors onto my 2.7 with cam and springs. Gauges don't work. do i need a i gauge cluster wiring harness? ive read all the threads about the swap and i don't remember this being mentioned.
    97 tacoma 5 spd 4 cylinder
    2001 330ci 5 speed
    83 733i 5 speed, (FS)
  • E30-323i
    • Jun 2008
    • 10
    do you have an "e" converting it to "i"??
    What did you have to change?? only the cylinder head of the "i" and the electric system?
    ill really apreciate your answer. Thanks
    • h82crash
      • 127
      He said cam, springs, and sensors. Here's a good article on a good site http://www.strictlyeta.net/technical/328i_1.html
      Search 2.7 stroker and motronic upgrade. Or this thread: http://r3vlimited.com/board/showthre...ronic+up-grade
      I've only read about having to jump a wire from the ECU to the tach, but they do say you need to upgrade to a 7k tach. Maybe they mean to swap the whole cluster. I haven't read of any other issues either. I'm about to do this swap in about a week. Hope you get it sorted.
      "Life is hard...it's a lot harder if you're stupid."
      Tom
      72 2002
      87 327i
      88 525i
      88 535i
      03 530i
      • TopOfTheLine89
        • Jun 2007
        • 919
        I already have a 7k tach that was swapped in and working.
        There are wires under the dash that connected to the old harness but the new harness has a different plug and different colored wires. Does anyone know about this. I guess that they go to the gauges because there is no other wiring going from the harness toward the gauges.
        If anyone could post up a pic of their installed ecu and wires underneath dash by the ecu that would be helpful. Also a close up pic ofthe engine bay on drivers side with air box removed. It seems the new harness is short 1 wire to go to the TPS or the ICV.
        2001 330ci 5 speed
        • TopOfTheLine89
          • Jun 2007
          • 919
          Anybody? I have been searching for 24 hrs now.
          2001 330ci 5 speed
          • h82crash
            • 127
            Sorry, I don't have any answers for you. Did you swap the whole cluster or just the tach? Does that make any difference? Is there anyone out there who has done this?
            Tom
            72 2002
            87 327i
            88 525i
            88 535i
            03 530i
            • Mitch M
              • 881
              What year "i" harness did u use? Big difference in C104 plug.
              • TopOfTheLine89
                • Jun 2007
                • 919
                Sorry i forgot to post, fixed this a few days ago, just had to jump tach wire from the c104 plug to the tach wire lead from the cluster under the dash.
                2001 330ci 5 speed
