Not your typical idle problem
  • Collin
    • 1736
    1988 325iC: bavauto chip, bavauto plug wires, K&N conical; otherwise engine is bone stock
    So I replaced my clutch about 2 weeks ago and ever since it's been idling rough at both hot and cold. To describe it let me say my car sounds like it has an awesome aftermarket cam, except that it doesn't and it sounds like ass. RPM is basically steady, but it knocks or misfires and shakes about. No hesitation on acceleration and no power loss or rough running at cruising speed. Since I've done all this work to it, it feels like it's 3X more powerful than before, except for the crappy idle.
    I've been running through the possibilities but now I'm just stumped.
    Things I've already checked/replaced:
    -O2 sensor has about 6 miles on it, tests fine
    -airflow sensor tests fine
    -throttle sensor tests fine
    -IACV tests fine
    -spark plugs were replaced 3 hours ago so it's not them (cylinder 4 had some unburnt fuel on it and smelled vaguely like oil).
    -spark plug wires all have same resistance (about 5.6 ohms all around, is this safe range?)
    -distributor coil is fine
    -brand new battery
    -vacuum leaks are all sealed up or fixed
    -oil dip and oil cap are both brand new and not leaking
    -all gaskets on intake side are brand new
    -timing belt/water pump/belt tensioner were replaced about 30 miles ago
    I can't think of anything else it might be. Help me my DD doesn't like stop lights anymore!
    The Keystone Killers
    With 73k+ post, you'd think he'd have learned a little about life.
    My first suspicion would be an intake leak if the only symptom is a rough idle, possibly aggravated by mis-adjusted valves.
    • ADEN
      • 620
      Temp sensor?????
      • Collin
        • 1736
        Originally posted by ADEN
        Temp sensor?????
        Do you know the check procedure for the temp sensor by any chance?
        • SpecM
          • Oct 2005
          • 4531
          check with an ohm-meter, the resistance should vary with temp, but I don't know the specs off-hand
          1989 cirrisblau-metallic 325i
          • Collin
            • 1736
            Does bentley cover the procedure?
            I noticed today the check engine light comes on, but only at idle, not while driving or accelerating.
            • Knockenwelle
              • Jul 2008
              • 395
              Maybe cold-start injector issue? This may appear in fuel mileage, too. How far apart did you have everything/what could have been disturbed? Did you wash the motor prior to working on it? Possibly cracked or defective plug? (new or not...)
              Mike
              '91 325i track car. Mostly...
              • Collin
                • 1736
                The idle is slightly better at cold, I figured that was the extra fuel being dumped. Maybe a fuel issue (clogged fuel filter)?
                I did have to disconnect the electricals on the fuel injectors, I'm sure they're back in the right order though.
                I had to take the intake plenum off to get at the last bolt way on top of the trans, it had corroded itself in there and had to be replaced. I replaced all the gaskets for the plenum though.
                No, I didn't wash the motor. I'm thinking the valves may be out of adjustment, so I'm going to take it into the local euro shop to check it out. I still have to check the temp sensor though.
                • SpecM
                  • Oct 2005
                  • 4531
                  no cold-start injector on is car
                  • allwheeldrive
                    • Jan 2008
                    • 272
                    Sounds like a vacuum leak to me. Did you check the main rubber intake hose? Possibly cracking on the bottom or somewhere you can't see it?
                    • TS87325IS
                      • Sep 2006
                      • 821
                      And check the little tiny rubber hose that goes to the bottom of the throttle body that comes from charcoal canister. definatly sounds like intake or vaccum leak.
                      mods: just meat and potatoes under the hood and wheaties on fire out back ;)
                      • SpecM
                        • Oct 2005
                        • 4531
                        buy some carb or brake cleaner and spray it around the air boots with the engine idleing. Listin for changes, this will indicate vacuum leaks.
                        Good luck, my air boot has a rip, and misses at high rpms (engine shifts under high load and exposes a small crack on it), it only $23 on Pelican.
                        • pilotskillse30
                          • Dec 2006
                          • 1957
                          I have the exact same problem...I mean EXACT! I have adjusted valves and new gasket on the valve cover, that overed a small leak there aswell, I changed the O2 sensor and plugs, wires, cap, rotor, coil is fine, timing aswell is checked, the shop I went to checked again for vacuum leaks and nothing...but I see here something about temp sensor, shy off sounding stupid how does this compnent affect the engine if it fails..I will check for more cracks. Oh and now I hear low speed clutch chatter is that something your having to RADIOCAMMBODIA and a slight whine under the hood aswell. Let me know how it goes and offer any advice if you find the fix.
                          • NC325iC
                            • Mar 2004
                            • 6565
                            does it sound like this
                            maybe your ignition wires are mixed up?
                            • Collin
                              • 1736
                              No it sounds perfectly normal once I apply any throttle, with no loss of power or anything, it just idles like crap.
                              I had a shop hook up a smoke machine to find any leaks and the only spots were the throttle body connection for the IACV and the brake booster hookup, both are sealed now.
                              I'm going to check temp sensor today and I'll get back with details on that. Otherwise I'm thinking valves, and I'll take it in for adjustment.
                              My 2 day clutch job has turned into a 2 month marathon of crap.
                              Edit: Let me see if I can record the sound for you guys.
