This problem has been getting worse so Im putting in an order for a starter today, but just wanted to know if anyone has ever had this problem. I turn the key to start, the starter spins freely and then will engage the flywheel after a few seconds. What would cause the bendix to be delayed like that? weirdness
WTF? starter spins first then engages...
sticky solenoid? that sure aint good for the teeth on your flywheel though i'd fix asap starters are cheap no biggie
'89 Alpine S52 with goodies -
Mine did that a couple of times, 2 wires on it were loose, tighten up and fixed.Comment
Could the mounting bolts be loose? A little wiggle on the starter will stop it from engaging correctly.The Keystone Killers
Originally posted by CabrioletWith 73k+ post, you'd think he'd have learned a little about life.Comment
