can they be removed with the manifold attached. im thinking they can but ive never pulled them with the manifold attached to the head. i told a friend that i would replace the injectors but i dont wan get into something and have it be more than i expect.
injectors
injectors
Originally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
DIVING BOARD DIVISION DIVISION IDIOTTags: None -
thanks. some ricer shop that claim to be bmw specialist told him that the manifold needs to be taken off completly to switch them. and they also charged him 2000 dollars to lower his car (springs, struts, and labor.)Originally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
DIVING BOARD DIVISION DIVISION IDIOTComment
If he's spending that kind of money, I'd want to be his mechanic :D
What injectors are you putting on? I'm going to be doing an upgrade on my beater/track toy 325is and trying to get an idea of what works and what doesn't.Comment
he is just putting stock ones in. he has to pass emissions. im gonna be doing some trade work. im changing the injectors and replacing a fuel line and he is giving me a b25 harness.
and after he passes inspection he wants to have a set of headers installed. i dont really like to shop to begin with. i went in there once wanting to buy a throttle cable for my e30 cause it was broken and my car was stranded, i get there and they have one laying around and they say they cant sell it to me because if they do then if they ever needed one they would have to buy one at full price(25.00 usd). i was like wtf.Originally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
What injectors are you putting on? I'm going to be doing an upgrade on my beater/track toy 325is and trying to get an idea of what works and what doesn't.[/quote]
I put 19# and an 027 AFM in my car with a K&N cone filter. It runs great. Somewhere on here someone put up some dyno specs before and after the install. It added 14RWHP IIRC. I say that after I had ordered the injectors but that would have been a selling point for me.
I paid $20 for a 027 AFM from a 530i, $40 K&N filter and $65 for tested design 3 injectors on ebay. Well worth the moneyOriginally posted by NicademusMy car beats off to that car. :bow:Comment
I paid $20 for a 027 AFM from a 530i, $40 K&N filter and $65 for tested design 3 injectors on ebay. Well worth the money[/QUOTE]
hahaComment
I have Taken Mine off a couple of times and all u have to do is disconect the fuel lines and the fuel pressure regulator then remove the 3 or 4 10mm bolts then pry up on the injector rail with a Screw driver then push then flip the rail so its laying on its side facing the intake manfold and then just pull out the injectors it should take no less then 20 mins.Comment
