early starter wired to a late harness?
  • akorcovelos
    • Dec 2006
    • 1149
    I have a 2.7i that I just installed, my original starter would just free spin but the spur gear wouldn't kick out to engage the flywheel. I got a early style starter to replace it but it has one less terminal than my late style starter.
    The Bently mentions post 88 cars having an extra wire, but I have heard all m20 starters work on all m20s. Anyone have any idea how to hook it up?
    Here is my original starter:
    and here's the early starter installed, notice the lack of the top threaded terminal.
    2012 MCSCC/NSSCC CP class champ
    HSAX Instructor
  • rs4pro3
    • 5808
    the early starter uses a spade connector instead of a ring connector for the black/yellow wire, so you need to clip the plug and put a spade connector on the harness.
    85 325e 2.7 ITB'd stroker
    • akorcovelos
      • Dec 2006
      • 1149
      so the battery positive goes on the right terminal (looking from the front of the car) as well as the thick red lead coming from the harness, but there are two other small black wires, one that comes from the same part of the harness as the thick red wire, and one that comes from someplace else, which one goes on the top spade connector?
      HSAX Instructor
      • rs4pro3
        • 5808
        both the small wires go to the same spade connector.
        • akorcovelos
          • Dec 2006
          • 1149
          hmm, would having the black wire that comes out where the red wire comes from on the same terminal as the red wire prevent the spur from kicking out? I thought it was strange that my starter worked fine when I pulled the motor and not when I reinstalled...
          HSAX Instructor
          • winfred
            • Apr 2008
            • 72
            to use the 1 small wire starter
            ground the smallest wire that was held with the 8mm nut it's green and black if i remember correct, it kicks out a relay during starting that powers down a few systems on the car to provide more power for the starter, without that you won't have windows and a few other things usually
            • akorcovelos
              • Dec 2006
              • 1149
              got the original (late model) starter working, just had it hooked up wrong...Thanks though.
              HSAX Instructor
              • h82crash
                • 127
                Do your windows work? The unloader relays attach at the starter and the green wire should be attached to the terminal between the solinoid and the starter.
                "Life is hard...it's a lot harder if you're stupid."
                Tom
                72 2002
                87 327i
                88 525i
                88 535i
                03 530i
                • akorcovelos
                  • Dec 2006
                  • 1149
                  yeah, got it hooked up correctly now.
                  HSAX Instructor
