so with some help I figured out that the oil gallery plug that hides behind the bottom tab of the water pump is leaking. :(
I was told to JB weld over it, sand down smooth so the pump sits flush and be done with it, but I would like to replace the plug with a new one, then JB it for insurance.
Has anyone else had to deal with this, and if so how did you handle it?
The only way I can think to do this is to drill a hole in the leaky plug and use a small screw driver to pry it out, then hammer in the new one. I'm just worried about metal chips getting into the oil passage.
