not a bad idea. Thanks for sharing.
Valves - time to do them
while your in there you can do plugs, wires, blow by hose (on top of the valve cover), and if needed a new valve cover seal. You might also want to paint the valve cover. I will be sure to do that next time. Those are the things you will directly touch by doing this job.
HopeThatHelps.
Good info Stereo.Comment
not sure on that.
you won't actually have the head open.. just have the valve cover off.. so you could change valve seals.. maybe even the valve springs.rmousir
'87is work beater
the RED BARON!
RUNNING GREAT!
After a $10.99 Intake Manifold Gasket.
sigpicComment
Valves will not close completely when the motor gets up to running temp. if they're adjusted too tight. THEN it will run like crap and no power. Do it by the book for best results. Seriously.sigpicIf it can't kill ya, it aint a sport!Comment
