hmmm is there like a number or somthin that i can look at to tell? and ill take them pics here soon
drive shaft question
it will say what the transmission on it somewhere, but you might not be able to see it because it is in the carOriginally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
DIVING BOARD DIVISION DIVISION IDIOTComment
ZF S5-16 i just found this on some website it said these transmissions came in early model 318i's and mine is deffenitly an early model when i search the vin# it says it was made in 84sigpic
Bad Ass....Comment
was only the motor swapped? or did the po swap the transmission too?Originally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
This is more than likely the problem. I believe I remember hearing the getrag 245 is shorter but I don't remember where I heard that.
OP, get a hold of a getrag 260. They are readily available and hell you could see the 245 and buy the 260Comment
thats probably what ill end up doing but right now i just cant afford it im in the middle of moving and kinda broke right nowsigpic
Bad Ass....Comment
