I have changed the water pump, thermostat, spark plugs, timing belt and oil changes every 3 months (1500-2500 miles). The engine has 137k miles on it and I am curious what else I should be worried about soon. I checked compression a little over a year ago and it was around 170 on all but the 6th cyl. which was 145 or 150. I'm not sure what proper compression should be at, and the compression tester I used might have been a crappy one but it was all I had. I know these engine can last 250k miles +. I just want this baby to last me a long time.
- in the next month or so I will replace the alternator because the bearing is going out.
- I also need to replace the oil pan gasket soon.
any suggestions? or common problems you all have noticed? thanks.
