Compression test
  • utketa
    • 30
    Compression test
    Ok so my b25 was leaking oil from the front oil return port, so i replaced the headgasket about a month ago. After the change it was still leaking until about a week and half ago, but now is not leaking. I thought the head was warped, but now i'm not sure since it quit.
    I decided to persue the state of the head with a compression test and here is what i came up with...all plugs out, fuel relay pulled, WOT.
    #1 - 155
    #2 - 160
    #3 - 152
    #4 - 145
    #5 - 120
    #6 - 170
    Now i'm not really sure what this is telling me. I haven't noticed any problems driving the car, but am concerned that they are all over the place. Should I try some seafoam in the crankcase? Any suggestions are appreciated.
    You need to do both a dry and wet compression test as well as a leak down test to figure out what's going on. Those numbers could mean anything (bad gasket, worn rings, or worn valves)
    • SpecM
      • Oct 2005
      • 4531
      +1 or a lot of other things, like an impropery seated HG or a little scratch on a cylinder wall
      1989 cirrisblau-metallic 325i
