i gotta change my reference sensor, the thing under the tranny by the speed sensor, and anyways, i cant get it out, i tried so pb blaster and vice grips but it wont budge
oh noes!
what ive done is used a punch and put it in the hex head and then hit the punch with a hammer.Originally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
DIVING BOARD DIVISION DIVISION IDIOT -
is your car a manual or an automatic?Originally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
DIVING BOARD DIVISION DIVISION IDIOTComment
ok, then never mind, if it were an automatic i was gonna tell you to just pry on it an if it broke you could always retrive it through the bottom vent on the auto.Originally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
Pliers?Comment
