WTF did I just break?
  • k_wakasugi
    • 214
    This morning on my way to work I heard a small pop, after which my car started to overheat really quickly. I could smell coolant so I knew something was up. This is what I found:
    The circled hose had broken loose, and was hanging with the metal piece pictured below still in it. Fat green arrow is where the hose would be if it was still attached (ran under the thicker hose) and connected where the skinny green arrow is pointing.
    Green lines indicate hose.
    Crap, something's broken. Question is, does anyone know the name, or maybe have a part # of the chunk of metal all these hoses connect to? Looks to me like the piece broken off in the hose snapped off of the part i'm looking for, but I don't know how.
    edit: sorry for the crappy cell pics (stuck at work), and for the laziness not looking this up. I normally would but I decided to clock back in and get a few more hours in while I'm waiting for a ride, so can't research. Thanks to anyone who can help!
  • kronus
    • Apr 2008
    • 13029
    That would be the water pump. An inlet broke off and you lost coolant.
    There's a good deal on water pumps in the group buy section, iirc.
    cars beep boop
    • k_wakasugi
      • 214
      lol, do I feel like an idiot. Thanks.
      • Devil Inc
        • Jan 2008
        • 802
        Umm, it looks like the thermostat housing to me.
        • rs4pro3
          • 5808
          Correct that is the thermostat housing you broke, that hose runs from the housing to the throttle body heater housing. Part #1 in the diagram
          http://www.realoem.com/bmw/showparts...59&hg=11&fg=35
          85 325e 2.7 ITB'd stroker
          • kronus
            • Apr 2008
            • 13029
            *%&. I think that's the second time I did that. That is the thermostat housing, not the water pump. Sorry.
            cars beep boop
            • themitchster359
              • 654
              def the thermostat housing. it's super easy to fix.
              89 Alpine White e30 325i
              • Optimator
                • 1396
                kronus, you must stop hanging around with Farbin Kaiber. Your short term memory has clearly been compromised.
                -OVULATOR (as named by jflip2002)
                Past Cars: Schwarz 1990 325i-2 (crashed), Calypsorot 1991 325i-2 Sport (rear ended)
                Now: Blake-stitched mediocrity :(
                • kronus
                  • Apr 2008
                  • 13029
                  But he gives such good massages, you know that's hard to leave behind.
                  cars beep boop
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    I really do. And you should see my carwash in a can.
                    • k_wakasugi
                      • 214
                      Thanks guys, I'll be replacing it today.
