Yes, you read this correctly. Spark Plug Blew Out?
I installed these plugs about six months ago, to replace a set badly worn from being in to long. The plugs went in with out a problem, and in tight. I was afraid of over tightening then.
The car had started running rough at idle the night before on the way home back from Ga to KY. I thought, maybe I had bought some bad gas.
The next day, I was pulling away from a red light, normally. No heavy acceleration and POP! It began to idle rough. My first thought was that something let go such as driveshaft, rod, crank or even a piston. It was a loud pop, like the sound of a shotgun going off. I pulled over and got out to check, found no leaks or pieces. My son was looking under the hood with me and asked about the loose spark plug wire, that is when I found the plug laying on the wiring harness attached to the strut column.
We regapped, put it back in tight and the car runs great again?
Has this ever happened to anyone else? I will check my plugs new every oil change to make sure they are still tight. This was a bit scary, thought I was going to need a new engine at first.
