opinoins on an engine pull
  • a_thomasmr23
    • Nov 2008
    • 152
    broke a timing belt so m20 is coming out what is the best way
    1. out from the top as per the bently
    2. drop it down and lift the car over (no shop lifts just floor jacks and such)
    bring it http://athomasmr23.mybrute.com
  • mikegar
    • Aug 2005
    • 523
    ive always taken them from the top. ive herd that taking them from underneath is eaiser tho
    Originally posted by Ferdinand
    I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
    DIVING BOARD DIVISION DIVISION IDIOT
    • tonytony
      Knee deep in poopie
      • Jan 2004
      • 3498
      taking it from underneath requires removing the front subframe and all that jazz that's hooked up to it, take it from the top
      • Mike
        • 932
        I took the car off the motor, it was kinda fun, in my driveway with a floor jack. My m20 had the auto still attached, but nothing on top of the block. I probably would not have done it that way if the head was still on it. I seesawed the car at the frame rail by the tranny, took off the rear wheels to get the max travel off the seesaw technique. even brought the struts, control arms, rack, and f sub. all at once. By myself.
        Supatek -noun - your basic know it all
