adjustable cam gear?
  • a_thomasmr23
    • Nov 2008
    • 152
    Does anyone know if someone makes one? I want to deck my head down to get a 9ish compression ratio but obviously am going to need to adjust the cam timing.
    also has anyone done this and what adjustment did you have to make? I turned my engineer friends loose on this so they should be getting back to me with some numbers at some point which i will post
    bring it http://athomasmr23.mybrute.com
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    They make them...hope you have deep pockets.
    -Andy
    • Justin B
      Sikky Nar Nar
      • Mar 2005
      • 4273
      There are a few different manufacturers actually.
      VAC makes one $$$
      IE sells some for $120. LOTS cheaper, IIRC they look the same as the Cosmo gears that are sometimes found on ebay.
      there's a couple other ones too, but they do exist.
      • a_thomasmr23
        • Nov 2008
        • 152
        thanks for the info guys
        • Knockenwelle
          • Jul 2008
          • 395
          Mine ended up needing about 6 crank degrees of advance. Getting a good dial indicator read on the valves was tricky! Have fun with the build!
          Mike
          '91 325i track car. Mostly...
