Car Not Starting
  • bimmerville
    • Feb 2007
    • 99
    Car Not Starting
    Help!!! 86es not starting We have checked every single connection,relay, fuel pump battery you name it. Can you think of anything else all Ideas incouraged!!!!
    Bimmerville
  • kronus
    • Apr 2008
    • 13031
    Do any lights come on when you go to the ignition On position?
    Are you getting fuel at the rail?
    Are you getting spark?
    cars beep boop
    • bimmerville
      • Feb 2007
      • 99
      yes yes an yes
      • kronus
        • Apr 2008
        • 13031
        Ok...
        Is it cranking and not starting, or not even cranking?
        cars beep boop
        • ethirdy
          • Nov 2007
          • 406
          fuel is definitely there. No spark at coil. Relays swapped no change fuel pump working new cap and rotor swapped no change ecu swapped no change
          Originally posted by alpinaclone
          Since the real economy is in the shitter, I say we start our own.
          This is how it works; you buy my junk, then I will buy more junk and so on so forth etc. etc. Think of the future of your children and buy my stuff.
          • abepark
            • Feb 2006
            • 384
            crank sensor what does it read for resistance?
            • ethirdy
              • Nov 2007
              • 406
              That was my next thought how do you swap it out I followed it from the crank it goes into the diagnostics plug?
