89 325iX - starting and idling, sputtering through exhaust - if you stand at the back of the car, the two exhaust tips almost alternate, pulsating. Low end acceleration is flat, bogged down. Get it up over 4k - not bad at all, revs smooth, pulls stronger. Let it get below 4, between 2-3, acts like a clogged cat, very restricted. (I cut the cat out, still doing it.)
Parts replaced:
fuel pump, filter, fuel pressure regulator
spark plugs, wires, cap, rotor
coolant temp sensor, engine temp sensor
afm, ecu
tps
oxygen sensor
removed catalytic converter
thermostat
Maybe clogged injectors? Ignition coil? CPS? Ideas? Ways to test?
Parts replaced:
afm, ecu
tps
oxygen sensor
thermostat
