Purple Power FTW for cleaning grease/dirt
Bought an 89 325is and need help "refreshing" engine and engine bay.
Purple Power +3. Plus a pressure washer.
We have a parts solvent tank at work, and I know friends with hot tanks, so the next time I pull my trans out to get fixed, its coming apart and everything is getting cleaned.Comment
id say seafoam the shit out of the engine!
FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
1989 325i - Project/weekend driverOriginally posted by scabzzzzI stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
2002 325i - DD
2005 Suzuki SV650 - ToyComment
I bought a water pump from bavauto. havent had a problem but its only been 12,000 miles. It does not have a plastic propeller.Comment
Just plan on pulling the head if only to replace the valve guide seals. Cleaning is so much easier...
Don't forget a new cam seal too.
GL, and welcome to the obsession!
LukeComment
Next question:
Under the headliner on the driver's side there is a domelight (where there is a suicide handle on the pass side) The light clips into a plastic holder which clips into the car's roof. Any ideas how to remove that plastic holder without breaking it? I trashed two already at the boneyard trying to take it out.Comment
It looks like every frigging seal on that engine is toast.
Do the camshaft sprocket seal. Break the torque prior to taking the timing belt off.
Do the rear main seal. You will need new flywheel bolts. Not a big deal and easy enough to do with the engine/transmission out.
Make sure your replace those rubber plugs at the end of the camshafts when you replace the valve cover gasket.
The lower timing case seals are more difficult because of the high level of torque on that nut. But, if possible, they would be good to replace too.
None of these seals cost a lot of money and they are all hugely easier to do with the engine out.
Use realoem.com to check out all the parts you will need.1987 E30 325is
1999 E46 323i
RIP 1994 E32 740iL
oo=[][]=ooComment
Nothing on eBay about a "ziz-wheel" and google was not much help either with something specific. All I found out is that they are available in different grit grades. Any pointers as to where I should look?Comment
