how easily should rocker shaft plugs go in ?
  • Jordan325iC
    • Aug 2005
    • 1697
    I am getting a bad oil leak at the front of my engine. My engine builder said that the camshaft seal was still good when he installed the new cam and didn't need a new seal.
    I installed new rocker arm plugs that came with the Victor Reinz headgasket kit, but I seem to remember them sliding in surprisingly easy, and I suspect this may be the culprit.
    How easily should rocker arm plugs go in? I think my VR plugs might been duds. What brands have you had success with?
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
  • Dyno4mance
    • 345
    Ordered mine from Bav auto and they were very firm pushing them in
    2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
    • Knockenwelle
      • Jul 2008
      • 395
      Mine were from a Reinz set, and needed black RTV applied to even slide into place. No problems.
      Mike
      '91 325i track car. Mostly...
      • norcalE30
        • Dec 2008
        • 932
        check the fronts, mine were in backwards from PO:???:
        when i put the new ones in right, they went in pretty easy
        Originally posted by kronus
        pff, all of you are slow as hell anyway. Eta > all
