just colored valve covers and intake manifold
  • sickbro91
    • Jan 2009
    • 95
    just have one question. on the side of the throttle body theres that tube that connects to the valve covers. when i was removing that the rubber was so old it just chipped away. is there any way i can run it without that? or is it 100% necessary?
  • scott_is
    • Aug 2007
    • 310
    Its the crankcase ventilation tube...No its not 100% necessary
    You will have to plug both end if you want to run without it or
    your engine bay is going to be coated with oil and you'll have a
    vacuum leak
    Scott
    • sickbro91
      • Jan 2009
      • 95
      ahhh. well the old tube was all craked and stuff maybe thats why my avlve covers were covered in gunk alright sweet im going to get some plugs today. in the valve covers tho. should i put a little fliter over it? so it canstill break a bit?
      • Pac0
        • Jun 2007
        • 43
        Just get the tube, unless you want to run the risk of high crank case pressures over a $2 tube.
        • sickbro91
          • Jan 2009
          • 95
          what if i did the filter thing?
          • CorvallisBMW
            Long Schlong Longhammer
            • 13039
            I'd say replace the tube, IIRC it's about $12, less than a filter.
            • kronus
              • Apr 2008
              • 13020
              16, and good luck getting the right one. The RealOEM part # is wrong.. I have the later-style hose sitting here because of that.
              cars beep boop
              • CorvallisBMW
                • 13039
                Call your dealer. Give them your VIN. Order part. Done.
                • dashboardmonkey
                  FUCK YOUR WAFFLES
                  • Jun 2008
                  • 6158
                  +1 do it right the first time
                  -Andy
                  • norcalE30
                    • Dec 2008
                    • 932
                    same thing happened to me, the tube was like $9 from North Bay Bavarian. plus you cant pas smog without it, instant fail.
                    Originally posted by kronus
                    pff, all of you are slow as hell anyway. Eta > all
                    • sickbro91
                      • Jan 2009
                      • 95
                      oh. so i just wraped the broken end with this rubber stuff and now its perfect. just for now. going to order new parts right when i take the engine out
