m20 mid-range hesitation
  • straight6pwr
    • Sep 2004
    • 3450
    ok guys so here are the symptoms:
    car revs freely to redline when in neutral
    car revs freely to redline with %0-%75 throttle
    car revs terribly from 2900-4200ish rpms at >75% throttle.
    so basically under heavy load, hesitation at mid-range rpms.
    i did as much research as a i could and found some information, but nothing that perfectly fits my situation. i can start replacing everything under the sun, but am looking for suggestions on what to check/replace first.
    AIR:
    already checked for vacuum leaks, nothing seems to be amiss. checked afm for free movement, checked out fine. going to also try one that is a known working one.
    SPARK:
    can this possibly be something with spark? cap and rotor aren't very new. wires are relatively new in their lifetime. going to try a different known working ECU, but the ECU is not that old (was replaced once already)
    FUEL:
    i really can test the flow of the injectors with the tools i own. could a dying pump cause this? or perhaps a clogged fuel filter?
    any input is greatly appreciated.
  • SpecM
    • Oct 2005
    • 4531
    I've heard of DMEs doing this
    does it happen intermittently, or every time?
    1989 cirrisblau-metallic 325i
    • straight6pwr
      • Sep 2004
      • 3450
      everytime since it started happening, and started means one day it wasnt, the next there was hesitation. it wasnt like i was getting a little hesitation at first and it got worse. off/on.
        This could be caused by a bad AFM.
        • a_thomasmr23
          • Nov 2008
          • 152
          i didn't think that the afm was used for measure at WOT? i think that the fuel filter is a fair guess for the first check. WOT is the highest fuel output time and when a clogged filter is mostly to show up
          bring it http://athomasmr23.mybrute.com
