Ac removal
  • pawi30
    • May 2007
    • 1091
    Ac removal
    just want to know if there is a DIY step by step with pics to remove it ???
    Originally Said by Bob Marley
    "BMW make pure trouble!"
  • thereisnoyun
    • Feb 2007
    • 2301
    diy? well couple things you need to note,
    - alot of them are 22mm two joints require the use of adjustable wrench,... unless you work on trucks and you ahve all tehse huge wrenches.
    - undo the glove box --> if you dotn know how to do this, please do not attempt to remove your AC.
    - undo the two fitting thats attach to the center blower unit, its behind the glove box, you cant miss it.
    - open the hood, undo the two connection fitting next to your hood latch thing next to the front battery location.
    - pull those lines out from the under the hood side
    - undo all the fitting on the dryer, again if you dotn know what this is... dont be doing this.
    - take out the dryer and associated lines
    - finally, go in front of the car,take off the bumper, if you can take the valence off it will make it infinitely easier as well
    - undo the condensor lines coming from the dryer
    - unbolt the fan and condensor unit and slide out. Its that simple.
    - ofcourse you ahve to unbolt the compressor from the block
    • pawi30
      • May 2007
      • 1091
      funny ... i dont have a glovebox or the front valence
