intermittent windows/motor died **HELP**
  • gwb72tii
    • Nov 2005
    • 3864
    don't know if the two could be related, but my windows haveworked/not worked for the last two weeks. fuses are ok. to get them to work i would got to the fuse box and wiggle the relays.
    so, i get in the car to head home from work yesterday, the car starts, idles for about 4/5 seconds and then dies. windows are working, car cranks, no start.
    on board fault code pulls a 1444 (normal), and my Peake tool code readout says normal as well.
    obvious areas are the ICV and fuel pump, but i have had zero indications of any issues before. does the ICV and pump just die without warning?
    i also checked the wiring/connectors and all appears to be ok.
    any ideas?
    “There is nothing government can give you that it hasn’t taken from you in the first place”
    Sir Winston Churchill
