Ok so this car, 86 325e, has oil in the intake manifold. I was told that it was a crank case ventalation problem that was not allowing pressure to escape and thus pushing the oil up past the rings and into the intake? looking for info, truth, solutions, and quickly. Thanks
oil in the intake mani?
Originally posted by NI_racing View PostSo i should take off the manifold and clean it as well as the boot to remove the oil residue.... but what about the oil coming into the manifold? Is it as simple as new rings? Or is there a bigger problem?1989 cirrisblau-metallic 325i
As simple as new rings? That isn't simple... well, I suppose the answer is simple. Changing them out is another thing entirely.
It is very common for there to be oil buildup in the manifold. It doesn't always indicate blowby. If it happens quickly or there is a lot of it, then maybe it is blowby. Otherwise just clean it up and keep an eye on it. If it oils right back up, then you might have a problem. If you notice, there is the valve cover breather hose that goes from the valve cover to the throttle body. Over time, this setup will always allow some oil into the intake. You can't really avoid it (without a separator of some kind... anybody know of a good one?)1987 E30 325is
1999 E46 323i
RIP 1994 E32 740iL
oo=[][]=oo
There are two paths for oil to reach the intake. One is from the crankcase and is the result of excessive blowby from worn or stuck rings. The other path is the result of leaking valve seals. A compression and leak down test will pretty quickly tell whether the oil is from a ring or valve seal issue.The car makes it possible, but the driver makes it happen.
Originally posted by NI_racing View PostOk so this car, 86 325e, has oil in the intake manifold. I was told that it was a crank case ventalation problem that was not allowing pressure to escape and thus pushing the oil up past the rings and into the intake? looking for info, truth, solutions, and quickly. Thanks| Jimmy | 1999 M3 | 1986 325 ES |
