I am working on a m20b25 engine that has hydo-locked bending #1 rod, causing the piston to come apart.
What happened-
car was having injector harness issue (common e30 problem). harness was corroding under the TB, due to the TB leaking coolant on to it. the connector was cleaned and die electic grease was put in the connector. this seemed to fix the problem most of the time. when the car started sputtering it would be shut off and playing with that plug would make the sputtering go away. the last time it happened, the car was started up and there was an instantly a knock. this is when the rod benty and things went down hill from there.
when the engine came aprt it was obvious it had hydo-locked. my question is: has anyone ever seen (in an e30) hydro-lock caused by an injector harness shorting out? I have ruled out water getting in the engine because it was not raining and the car had not been drivin through a puddle, or anything like that.
thanks for any help i can get.:D
What happened-
