Vacuum hoses
  • SEdgell
    • Jan 2008
    • 348
    Vacuum hoses
    I'm looking around trying to find a vacuum diagram. Does anyone know of one?
  • Liam
    • 753
    What car? the only ones that are a little complicated are M10 powered 318i (US models anyway).
    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
    • SEdgell
      • Jan 2008
      • 348
      86 325es....I have a line on the intake elbow, between the throttle body and air sensor, that's got a large bolt blocking it off, I'm just curious where it's supposed to go. But then again, I didn't do it, so it's hard to tell, it may be an elbow from a differnt model, and mine may not actually need that vacuum line.
      • turninconcepts
        • 1
        On my 86e that goes over to the valve cover breather.
        • Liam
          • 753
          I think you have the wrong boot on it, (if I'm guessing / understanding you right) that goes to a valve on the vacuum assist hoses in later cars.
